Old    josh diller (tntrider)      Join Date: Jun 2007       09-14-2010, 1:13 PM Reply
For starters... I know this boat is in a different class than any competition wake boat.
My cousin just bought the 2010 model of this boat. I was curious if anyone has ridden behind it. If so, how did you weight it for wakeboarding and wakesurfing (if possible) I am assuming since there is no propeller it will surf the same on both sides. I believe it has 600lbs of ballast in 2 hard tanks.
Any info about this boat or a similar boat would be great.
Thanks!!!
Old    Ken Toby (towboat_222)      Join Date: Feb 2007       09-14-2010, 2:34 PM Reply
The boat comes standard 1000lb bag in middle. It is ok for boarding not worth anything for surfing. The boat tears the water up to bad. To much white water.
Old    Brett B. (Brett_B)      Join Date: Sep 2010       09-16-2010, 9:36 AM Reply
Since it's a new boat, you probably have as much experience with it as anybody, be sure and post up any pictures and videos when you get to check it out.
According to the Sea Doo specs it has one 600lb ballast bag in the ski locker. You would probably need to add another 1000lb or so near the back to make a noticable improvement in the wake. Here is the only vid I have found so far of people boarding behind this boat:
http://www.youtube.com/watch?v=q3RM9eB4cio
Of course the wake is frothy in the middle from the jet wash, but the ramps actually don't look too bad.
It would definitely need more ballast for surfing, but once you have added it the boat should be good for surfing. Several people on the Yamaha forums have plenty of success surfing behind their boats, and they are pretty similar in design.
