Old    camsask            08-13-2003, 6:07 PM Reply
what angle would you suggest to take for big air?....90deg. edging through or a litttle less...
Old    buttacup            08-13-2003, 6:43 PM Reply
Try reading Trick Tips on progressive edge and going wake to wake.
Old    mayday48            08-15-2003, 8:26 PM Reply
progressive edge, man... cant stress that enough
Old     (thelakeisglass)      Join Date: Jul 2003       08-16-2003, 7:06 AM Reply
The last Wakeboarding Magazine has a great article on getting air
Old                08-17-2003, 4:42 PM Reply
If you edge too hard (i.e. 90 degrees to the boat) you will get pulled off of your edge and will flatten out the board. You will go up b/c you are going fast but to get real air you need to edge up the wake which means a lot less than 90 degrees (exception: Darin Shapiro when doing a raley). Get Higher Education and watch the angles the pro's take.
