Old    Mario (mdaijogo)      Join Date: Mar 2010       08-31-2010, 8:27 PM Reply
Can someone tell me where are good spots on an DHM dual axle trailer to use a floor jack on? I need to remove a wheel to check the brakes and want to make sure I lift it correctly.
It has no leaf springs. It is a torsion type setup. Solid beam across to a pivoting joint to wheel.
Thanks.
Mario-
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       08-31-2010, 8:34 PM Reply
On tandem axle trailer I have always used a floor jack inbetween the tires where to leaf springs come together. Just make sure that you chock the tires on the other side. If you are going to be under the trailer, it is always good to use a jack stand as well.
Old    Meathead (meathead65)      Join Date: Sep 2006       08-31-2010, 9:01 PM Reply
Mario, place the jack directly under the axle, as close to the wheel as you can get without hanging up on anything.
Old    Mikeski (mikeski)      Join Date: Aug 2003       08-31-2010, 11:26 PM Reply
I don't even bother with a jack on my tandem. Just drive one wheel up on a 4x4 and it lifts the other off the ground. If you can't move the trailer then you can also use a bottle jack. I prefer my bottle jack over a floor jack if I don't have it hooked up to the truck.
Old    D H (dhcomp1)      Join Date: Mar 2010       08-31-2010, 11:27 PM Reply
Really, on a trailer, any main frame rail or axle location is fine.
The best is lifting the axle you need to work on, as close to teh wheel as you can get.
Lifting from the axle allows you to get the wheel off without first letting the suspension droop, like you would have to do if you lifted from the frame.
