Old    Phil (mmobius2001)      Join Date: Jun 2004       08-26-2010, 5:04 PM Reply
i have super glued them in the past, but the rubber inserts are so loose and falling off the inside of the rack (where the board sits)
what kinda glue can i use to fix this once and for all?
i also have a Liquid force surf board where the top is pealing, have re-glued using numerous products multiple times but just wont stay.....
Old    Cory McLean (kikitlo)      Join Date: Jul 2005       08-26-2010, 6:13 PM Reply
Try silicone. Make sure you clean the inside of the rack with IPA first. You may also try a 2 part epoxy.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       08-26-2010, 6:25 PM Reply
Indian Pale Ale?
Old    SamIngram            08-26-2010, 8:20 PM Reply
Isopropyl alcohol!!
I prefer pipe insulation for board rack padding.
Old    Adam Fullmer (adam4x4)      Join Date: Jan 2009       08-27-2010, 7:27 AM Reply
i used 3M weather strip adhesive. It also comes in black.
Old    Dave (bcrider)      Join Date: Apr 2006       08-27-2010, 9:10 AM Reply
^^^ i used that and I also just used super glue
Old    Luke Henry (star_one_wake)      Join Date: Nov 2009       09-03-2010, 10:49 AM Reply
Gorilla Glue is the S***! Clean out the inside and use that and you should have no problems!
Old    RM (RPM_DLX)      Join Date: Jul 2010       09-03-2010, 12:40 PM Reply
I cant say at how well they hold up but I just used liquid nails on mine. I figured if this doesnt hold up then its off to get some locktite 2 part epoxy.
Old    Art (rallyart)      Join Date: Nov 2006       09-03-2010, 4:19 PM Reply
Superglue is a cynoacrylate so it is brittle and not suitable for plastic to metal. Gorilla Glue or some other urethane will work the best. Many contact cements are also good. They can be removed easier than the urethanes. The 3M weatherstripping adhesive should be great.
Like Sam said, the prep is important. Clean old glue, slightly rough the surfaces, use alcohol to remove any oils or residue.
