Old    Mase (superair502)      Join Date: Mar 2010       08-21-2010, 9:24 PM Reply
Ok so I have pp star gazer on my 01 super air. When playing my stereo loud or operating several accessories my perfect pass shuts on and off repeatedly very fast. I thought this could be due to it getting low voltage so yesterday I installed a 100 amp alternator to replace the factory 50 amp. This did nothing. My batteries are both set up independently with a Deka deep cycle running the ballast pumps, stereo and cd player. Also I have a interstate cranking batt running my motor, dash and perfect pass. In between is a voltage regulator. Everything seems to work fine until the pp starts kicking on and off. When it does this the voltage on the dash gauge jumps wildly. Any ideas? I mean I thought the old alternator wasn't making enough power but I have double the amps now and there is hardly any difference
Old    A-dub (behindtheboat)      Join Date: Aug 2006       08-21-2010, 9:53 PM Reply
a short in my navigation lighting caused mine to do similar, but would stop because the short would throw the breaker
Old    Mase (superair502)      Join Date: Mar 2010       08-21-2010, 10:27 PM Reply
Yea mine isn't throwing any breakers just turning on and off non stop
Old    Adam (apwrx)      Join Date: Feb 2008       08-21-2010, 10:44 PM Reply
Mine did the same but it was due to a bad battery.The battery tested fine but I threw a new one in anyhow. Problem solved hasnt happened since.
Old    Mase (superair502)      Join Date: Mar 2010       08-22-2010, 6:47 AM Reply
Adam did u have the same dual battery setup as me?
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       08-22-2010, 7:19 AM Reply
It can be caused by where you tap into the +12v power.I was having the same problem when I would adjust the trim tab while PP is engaged.I called PP and they told me to make tthe +12v connection the frist connection coming from +12v on the ignition switch.I had mine connected to a +12v pole on the back of a gauge and due to voltage drops on the gauges the PP was not getting enough voltage.I switched it and it has worked fine since.
Old    Mase (superair502)      Join Date: Mar 2010       08-22-2010, 1:07 PM Reply
Are u talking about the ignition in the dash
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       08-22-2010, 1:31 PM Reply
Yes the switched +12v from back of key switch(ignition switch).
Old    Mase (superair502)      Join Date: Mar 2010       08-22-2010, 10:18 PM Reply
That did it thanks!!!
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       08-23-2010, 6:37 AM Reply
Cool,glad it worked out for you.
