Old     (waketowake)      Join Date: Jul 2007       08-22-2010, 12:31 PM Reply
my screen is blank, but when i push ON it still works and sets the speed. When i get back to my lift you can sorta see the numbers when i flush the boat(sometimes you can read it perfectly)... I posted something on here about this a couple of days ago, and i was told to push in a chip, I did that and it didnt work.
Old     (blkchevy)      Join Date: Jun 2008       08-22-2010, 8:58 PM Reply
having the same problem tried all connections and still no luck any help would be great its very frustrating.
Old     (waketowake)      Join Date: Jul 2007       08-23-2010, 6:11 AM Reply
I think its a battery problem. I'm gonna get another battery, and see if it helps, or turn of my speakers.
Old     (olmoomba)      Join Date: Apr 2010       08-23-2010, 7:34 AM Reply
Definately check your voltage, if the moisture wasn't an issue. Get a Voltmeter and back track. Start at the alternator, then to the starter (my issue was the little wire at the starter that is by itself on its own tiny post), then PP input power and then output power.
