Old    Ryan (ryanw209)      Join Date: Jan 2010       08-20-2010, 11:53 AM Reply
Hey guys/girls.m The other day I was out and my perfect pass started dropping the boat to neutral as soon as it would kick on. The servo motor test seems to be working on but the phase test shows 0 continuity on the black wire. I tested the wires at the master unit under the dash and it seems to have power there. I'm leaving for a camping trip this evening and would like to get the PP working before I go. Has anyone had this problem before? Do I need to get a new servo motor or could it just be the wire? Thanks!!
Old    Ryan (ryanw209)      Join Date: Jan 2010       08-20-2010, 4:57 PM Reply
bump
Old    Antonio Vega (t0nyv831)      Join Date: Jun 2008       08-20-2010, 5:09 PM Reply
I would reseat all my cables at the master unit and servo motor to remove any oxidation from the contacts. BTW, do you have gps or paddle? Reason I ask is because mine was doing the same thing (Speed would drop off) and come to find out it ended up being the location of my gps puck. It was being covered every now and then from people riding in the bow. GL.
Tony
Old    Spencer Anderson (AndersonMC)      Join Date: Mar 2010       08-21-2010, 1:54 PM Reply
I had the same problem and had to finally take it to the shop. Servo motor ended up being bad and they had to replace it.
Old    Richard White (4white)      Join Date: Apr 2010       08-24-2010, 10:38 AM Reply
Hey Ryan
I too have a 06 V215 and my PP servo motor went on me, just call the guys at PP and they can ship you a new servo in a couple of days. It is really easy to swap out, it will probably take you 20 min.
Old    Ryan (ryanw209)      Join Date: Jan 2010       08-25-2010, 2:06 PM Reply
Thanks for the replies guys.
Antonio - I have a paddle wheel type
Richard- I have a feeling the servo is going out but I did use it this weekend and it worked on and off so that makes me think it may be a bad connection somewhere...
Old    Trace (trace)      Join Date: Feb 2002       08-25-2010, 3:27 PM Reply
You can take the servo motor apart yourself and clean the rust out. I had to do this to mine about 3 yrs ago, and it's still working great. It is very simple to disassemble.
Old    Fred (olmoomba)      Join Date: Apr 2010       08-26-2010, 9:54 AM Reply
Also check your connection at the gold resistor. I had a problem with that breaking yet still intermittent contact because of the shrink tube.
Old    Ryan (ryanw209)      Join Date: Jan 2010       08-27-2010, 12:04 PM Reply
Fred I'll check it out.
Trace- I went out to work on it again yesterday and now the servo is completely seized up. Looks like I'll probably be spending the $165 on a new one....
Old    Trace (trace)      Join Date: Feb 2002       08-30-2010, 3:18 PM Reply
Mine was completely seized up when I took it apart.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       08-31-2010, 6:17 PM Reply
Dont spend the money! Mine was seized as well and it came apart and cleaned up in a jiffy. Back working like new. Check my thread about it for more details...
