Old     (softleeli)      Join Date: Jul 2010       08-19-2010, 8:06 PM Reply
MXF Converter Mac - Convert mxf file to WMV/MOV/AVI/MP4 on Mac OS with Mac MXF Converter.
MXF Converter Mac is an powerful partner for you to convert mxf file which is not compatible with many programs on Mac. You may have problem to play, edit or use mxf format. So are Panasonic HVX200/HPX300 MXF files, P2 MXF files , Canon XF300/XF305 MXF files, Sony EX camera mxf files.
The Material eXchange Format (MXF) is an open file format, targeted at the interchange of audio-visual material with associated data and metadata. MXF is self-contained, holding complete content without need of external material and bundles together video, audio, and programmed data.
As we all know, the P2 MXF format means high quality and huge file size. When recording in AVC-Intra 100 mode, a 64GB P2 card can be filled up in 64 minutes. It takes long time to copy the HD MXF files, and astonishing space to save them. So you will need a MXF Video Converter for Mac to convert mxf file to other format video on Mac so that the mxf can be compatible with other devices like iPod, iPhone, PSP, iMovie, FCP, etc.
MXF Video Converter Mac is the best mac mxf converter for you to convert mxf file to friendly video formats just like avi, wmv, mp4, mov, mpeg, etc for playing on iPad, iPod, iPhone 4, iTunes, PSP, Apple TV, Android Phones, etc so that we can watch our favorite mxf conversion file everywhere. With the excellent mac mxf file converter, convert mxf within several simple steps. MXF Converter Mac is the best partner for camcorders which record AV data as MXF (Material Exchanged File) files with metadata.
How to convert mxf video to avi/wmv/mp4/mov/mpeg/iPad/iPod/iPhone 4/iTunes/iMovie/FCP on Mac?
Step 1: Load mxf video files to MXF Video Converter for Mac
Free download, install and run Mac MXF Video Converter, then click "Add" button to import mxf video files into mac mxf video converter. As the program supports batch conversion, you can convert all added files one by one automatically.
Step 2: Select output format parameters
In the drop-down list next to "format", select output format that match your device select the destination in the drop-down list next to "output".
Tip:
Edit Flip Video: You can only get the desired segments by setting the start time point and end time point.
Crop video clips: Switch to crop window, you can remove unwanted parts around the video.
Step 3: Start convert mxf video files
After all the necessary setting have been done, click "Convert" button to start converting automatically
