Old    Jason Kennedy (txwake08)      Join Date: Aug 2010       08-16-2010, 9:00 PM Reply
I have 05 Moomba XLV Gravity Games Edition with the two rear ballast and center ballast plus an extra 500lb fat sac......any suggestions on how to setup the weight and what speed to run it at, wake plate adjustment??? Just picked up the surfing and just havent had much luck on getting a good wake going. Thanks!!
Old    Lakewakes Wakesurf Boards (brewkettle)      Join Date: Jan 2009       08-17-2010, 7:07 AM Reply
you may try the moomba site, regular foot set up is harder to get right then the goofy side. on mine i also replaced the platform to get it out of the water when it is in surf mode. I just picked up the 1180 bag for the front, so i will try this set up next for goofy side.
1180 center
400 left rear
750 right rear
400 under seat behind driver
plate all the way up, ( needle on gauge to left )
12 to 13 mph
I have surfed with just a 750 bag in the right rear corner and it seemed to work at 11 mph
Old    Jason Kennedy (txwake08)      Join Date: Aug 2010       08-17-2010, 8:34 AM Reply
Thanks for the info!!
