Old    Adam R (wakecumberland)      Join Date: Oct 2007       08-09-2010, 7:35 PM Reply
I went for a toe 3 this weekend. I havent landed any 3s yet but have all my 180s w2w. TIps are appreciated!
Old    Dallas Cowboys #1 Fan Robert T (cwb4me)      Join Date: Apr 2010       08-09-2010, 9:18 PM Reply
more legs push harder to get more height.
Old    Adam Barry (adambarry)      Join Date: Sep 2008       08-10-2010, 12:15 AM Reply
Keep the handle in close. Pull it to your hip and keep it around your hip until it is in the small of the back. You kind of let it out and that will pull you over your nose a bit. Also try and catch the handle right as you land (for me that always puts me in the right position rotation-wise) and make sure to land over your toes. You have enough height to land it you just need to be positioned right on your landing. Keep trying, you will get them. Once you land it, its pretty smooth sailing from there. It is one of the easiest tricks to do once you figure out the landing.
Old    alan plotz (alanp)      Join Date: Apr 2001       08-10-2010, 5:41 AM Reply
this is 2 180's. spin the first then go for the second. its not a 360(i.e. done all at one time like others). when you land you will be looking behind you away from the boat similar to a bs 180. youre on the right track. keep the boat slow and dont worry about going wake to wake.
Old    Adam R (wakecumberland)      Join Date: Oct 2007       08-10-2010, 7:40 AM Reply
Thanks guys, I'll try again on Friday!
Old    Alain (ak4life)      Join Date: Nov 2003       08-10-2010, 6:41 PM Reply
Nice work! Looks to me like you could have ridden all three away if you had the handle. I'd practice on passing the handle. A drill that's helped me was to learn how to ride switch blind and pass the handle back and forth behind my back while maintaining TS riding position. This is to simulate late handle pass for a TS3. I also learned them one wake outside in first. Once I took them w2w, the problem I had was loosing the handle due to the increased line tension. Finally figured out the problem was with my progressive edge and learned to cut harder at first and ease off my edge before the wake. The other piece of the puzzle is a switch BS1 so I could grab the TS3 with the front hand and hold all the way through to the blind landing. That one is still a work in progress. Anyway, looks like you're on the right track, keep at it and you'll have it! :-)
