Old    Chris Drymalla (cdrymalla)      Join Date: Aug 2009       08-08-2010, 12:05 PM Reply
I am reworking the ballast system in a 2000 air nautique. I realize that pretty much everyone goes with flexible tubing, but is there any specific reason to no use pvc pipe? It is so much cheaper and seems like it could make for a very clean install.
My thoughts as to why someone may not use it:
1) may become brittle
2) may knock around in boat crack
3) harder to work around once installed (e.g., can just move a flexible tube out of the way
4) More prone to cracking during a freeze if not completely drained
Old    James (Silverbullet555)      Join Date: May 2010       08-08-2010, 1:32 PM Reply
I think you just about nailed it. Installation is easier with with flexible tubing as well and allows for movement as bags fill and empty.
Old    Jacob Ruppert (jacobs0222i)      Join Date: Sep 2008       08-08-2010, 7:44 PM Reply
Just use Flex PVC. You can still use Blue Glue.
http://flexpvc.com/cart/agora.cgi?pr...VC_Pipe_1_inch
Old    Chris Drymalla (cdrymalla)      Join Date: Aug 2009       08-09-2010, 6:02 AM Reply
Thanks for the replies.
Jacob, that is good reminder. I saw some of that at Home Depot a coule of weeks ago and forgot all about it. Seems like a reaonable price per foot.
Thanks.
Old    WAlove (masonwakerider)      Join Date: May 2003       08-09-2010, 8:51 AM Reply
glued / cemented/ soldered connections are not coast guard approved because, the amount of vibrations seen in a boat over time can cause those types of connections to fail. Thats why all plumbing from the factory is hose, hose barb, hose clamp.
