Old    Tomas Donnelly (Tmannsx80)      Join Date: Mar 2010       08-06-2010, 10:31 AM Reply
I have a 2003 Mastercraft 280 vld with the 8.1 Inmar liter engine and I think my fuel pump just went bad. I pulled the fuel pump and ran the serial numbers but came up with nothing the number on it was 71-339 and is made by carter. Any suggestions on where i can find a replacement pump asap or rebuild the pump. Thanks!
Old    Edgar Ramon (jame04)      Join Date: Nov 2007       08-06-2010, 11:00 AM Reply
just did this, easy! Autozone part #2044
let me know if you need anything else
Old    Tomas Donnelly (Tmannsx80)      Join Date: Mar 2010       08-06-2010, 11:48 AM Reply
Thanks alot edgar, was just curious what that part number is ? is it a replacement or a rebuild? Is it marine grade?
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       08-06-2010, 11:53 AM Reply
Take it to your dealer and they will replace the fuel pump module for $700.
Autozone DIY for less than $100.
There is a huge thread on TMCowners about it.
You know why this happened, don't you?
Old    Tomas Donnelly (Tmannsx80)      Join Date: Mar 2010       08-06-2010, 12:01 PM Reply
In the $100 DIY what does that all come with? And why does this happen? Thanks alot for the response!
Old    Edgar Ramon (jame04)      Join Date: Nov 2007       08-06-2010, 12:04 PM Reply
swap out the pump, thats it. go to mc owners web site and there are pics and everything.
running the oat low on gas!!
Old    Tomas Donnelly (Tmannsx80)      Join Date: Mar 2010       08-06-2010, 1:30 PM Reply
When I call autozone they say that nothing shows up with the part number #2044. Are there any other numbers i need to tell them ? how do i describe it? thanks
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       08-06-2010, 2:02 PM Reply
This is what I am talking about. You don't have to read all 18 pages or whatever. The meat is all in the first few pages.
http://www.mastercraft.com/teamtalk/...l+pump+numbers
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       08-06-2010, 2:09 PM Reply
Same thing happened with my Indmar/Malibu fuel pump. I had read that it was a pump made by carter and I found it a NAPA for 150. I had several dealers tell that it was an AC Delco pumps and I needed to buy it from them prices ranging from 260 to 400.
Pulled the old pump and it was indeed an orig carter pump from the factory. Sometimes dealers can me dishonest or misleading to get a sale
Old    Rick Gardner (rgardjr)      Join Date: Jan 2010       08-06-2010, 2:39 PM Reply
These are the part numbers for the fuel pumps:
AC Delco EP356
Airtex E2044
NAPA P74118
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       08-06-2010, 4:09 PM Reply
I used a Bosch pump that cross referenced as compatible with the EP356 at my local Napa auto parts. About 20 hours on it so far and all is good.
Old    Gary (sanger)      Join Date: May 2002       08-07-2010, 11:02 AM Reply
It's pretty sad that us MC owners have to worry about getting below 1/2 tank of fuel because of fuel pump problems
Old    Brian Aubuchon (dunesday)      Join Date: Nov 2007       08-07-2010, 6:56 PM Reply
Double check your connection going into the tank. Mine acted as if the fuel pump was going out. It turned out the connection was bad at the coupler. Cleaned it up and all was good.
