Old    Parker Caskey (wakesetter_WW)      Join Date: Jul 2010       08-01-2010, 11:18 PM Reply
I've done some surfing behind our boat and can last a long time without the rope but can't come close to getting air. I'm always really close to the platform because the rest of the wake is washed out. Any advice on how to weight the boat. I have the power wedge but standard ballast in the rear and center. I also have some fat sacks from my old boat that i could try. Any tips??
Old    Scott (scottnaz)      Join Date: Feb 2008       08-02-2010, 8:21 AM Reply
It's also going to depend on the board you're riding
How much weight is the standard ballast in the rear and center? How big are the extra fat sacs you have?
How fast are you driving?
Old    Who Cares (liljohn)      Join Date: May 2007       08-02-2010, 1:37 PM Reply
with stock ballast you will NOT go far. I have a vlx and run 1000 on top of the rear tank in the corner. and 450 under the seats on the surf side. 11-12mph. good long wave and more than enough room to get air. If you wanna max the weight run two more 750# bags end to end on top of the surf side seats starting from the front and going back.
Old    Parker Caskey (wakesetter_WW)      Join Date: Jul 2010       08-02-2010, 2:45 PM Reply
The standard ballast i believe is 500 in the center and 250 in each rear tank(2). My fat sacs are 250 each and i have two. I typically ride at 11 mph. I am thinking I should try with center and tank on surfside full. (I surf goofy) Then put one sac on top of the rear tank on the surfside and put the other either on or under the rear seat on the surf side. Any advice on using the power wedge??
Old    Parker Caskey (wakesetter_WW)      Join Date: Jul 2010       08-02-2010, 2:49 PM Reply
Board is a 06 Hyperlite Broadcast 4'9"
