Old    Jason Metaxas (dirty30)      Join Date: Aug 2006       07-30-2010, 10:11 AM Reply
Does anyone know if there are seperate fuses for each pump?the is one circuit breaker under the dash that i found.the center works fine but the outsides i get nothing.i switched the wires and all the pumps work.maybe a short?
Old    Brett Yates (polarbill)      Join Date: Jun 2003       07-30-2010, 10:34 AM Reply
In 06 did they have the rocker switches or the lighted toggle switches. If it is the lighted toggle switches I think there is a circuit breaker right next to each switch.
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       07-30-2010, 10:36 AM Reply
My 06 X45 has a breaker box in the port side rear compartment up against the front wall of the compartment. You hardly notice it unless you lean over the seat with your head in the compartment and look towards the front of the boat. I bet you have popped the circuit breakers there. Jut a click to reset and you might be good to go.
Good luck!
Old    Jason Metaxas (dirty30)      Join Date: Aug 2006       07-30-2010, 5:41 PM Reply
It is the lighted toggles.i will look for that.never seen circuit breakers in there.thank you ..hopefully its in there
