Old    Bryan Poss (burn229)      Join Date: Nov 2007       07-29-2010, 8:06 PM Reply
I lost my ignigtion key for my 07 Sanger v215 has this happened to anyone? How do I get a new key?
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       07-29-2010, 8:59 PM Reply
You might be able to call Sanger with your hull ID number, but you may have to prove you own it. The other option is pull the ignition and take it to a locksmith and they can make a key.
Old    D H (dhcomp1)      Join Date: Mar 2010       07-29-2010, 9:05 PM Reply
Both those options are expensive.
Are you handy at all?
You can probably change the whole ign switch and get 2 new keys with it in about 15 min. They are only like $25-40, way cheaper than a locksmith or getting a dealer involved.
And really, most boat igns suck. YOu can cram just about any key you arent' fond of in there for temp purposes. Mail keys work especially well.
Old    Bryan Poss (burn229)      Join Date: Nov 2007       07-29-2010, 9:22 PM Reply
I can change fluids and install stereo head units is that handy enough?
Old    Dave (bcrider)      Join Date: Apr 2006       07-30-2010, 9:06 AM Reply
Just replace the ignition yourself. You'd be able to do it pretty quick depending on your access to the back of the dash. Usually about 4 wire terminals or so on that back that just need to be pulled off. I don't even bother taking the key out of the ignition.
Old    Bryan Poss (burn229)      Join Date: Nov 2007       07-30-2010, 1:36 PM Reply
I replaced the ignition switch today in about 5 minutes. The only problem now is my blower won't go on. I hit the reset button but it still wont go on. Any ideas what is causing this? Low batteries maybe?
Old    Bruizza (bruizza)      Join Date: May 2009       07-30-2010, 1:40 PM Reply
Sounds about right for how long it takes to swap an ignition. Blown fuse or low battery is my guess for the blower.
