Old    Bu Coo (brett564)      Join Date: Jul 2006       07-23-2010, 2:21 PM Reply
I have an 08 Malibu LSV with the Hammerhead engine. For the first year I had the boat I remember being able to hit about 43 MPH before the speed topped out, and no more speed was possible. No rev. limiter would ever kick in. I don't remember ever looking at how many revolutions the prop was spinning at though. This year, I can't seem to break about 37 MPH. The difference is what I guess can only be the rev. limiter kicks in right about 4800 RPM (or 48000, whichever makes sense). I don't have my owners manual with me and I can't figure out what the rev. limiter is set at or even if my boat has one? The reason I think its the rev. limiter is simply because right at the same point, the engine quickly and breifly drops power, and the RPS drop slightly. It takes about 2 to 3 seconds to bring it back up, but feels exactly like a speed governor in a car.
Does anyone have an explanation for this?
Old    Matt (slappie75078)      Join Date: May 2010       07-23-2010, 2:24 PM Reply
It could be your prop key slipping, allowing the motor to hit the rev limiter without the boat hitting top speed. Check that first and see. If you prop key slips, your prop will not spin as fast as the shaft so the motor is turning more rpm than the prop, thus the lower top speed and higher motor speed and hitting the rev limiter. Good luck.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       07-23-2010, 3:13 PM Reply
5250 rpm is where the rev limiter should kick in on that motor. With the stock ACME 537 prop you will only be able to hit rev limiter in ideal conditions. If you're hitting it at 4800 rpm something is wrong and your dealer needs to take a look at it.
Old    Bu Coo (brett564)      Join Date: Jul 2006       07-23-2010, 3:14 PM Reply
hey, That makes sense. And just to confirm, your talking about the actual key which is part of the mechanism that allows me to change props and take them on and off of the shaft?
Old    Bu Coo (brett564)      Join Date: Jul 2006       07-23-2010, 3:15 PM Reply
Nu Bu, 5250 would make sense that was what it should be. I remember getting a software upgrade last year. Could that have changed something?
Old    D H (dhcomp1)      Join Date: Mar 2010       07-23-2010, 3:54 PM Reply
Same lake? Elevation will make that much different is WOT speed and rpm.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       07-23-2010, 4:31 PM Reply
Check your spark plugs, most dealers are going away from the delco plugs that are gapped at .065 and going to NGK gapped to .045 instead. This is eliminating alot of those plug issues they
ve been having.
Maybe they loaded the wrong program in your boat when they updated it?
