Old    Adam Barry (adambarry)      Join Date: Sep 2008       07-21-2010, 1:36 PM Reply
I have an 09 Lyman and I put my 07 shanes on it and there is only one stance I can put them in. There are three places to put bolts but when I put my bindings on the board they reach all the way out to the outer bolt on each set. I would like a wider stance so I was wondering if the newer lf bindings had a different bolt setup.
-Adam
Old    Chris Halfmoon (moon)      Join Date: Oct 2008       07-22-2010, 12:17 AM Reply
Yes, newer bindings have a different bolt pattern setup. 2007 LF bindings use an 8" binding plate, but the 2009 boards have an 6" insert spread (this combo only gives you one stance option). If you go to FAQ at evogear.com it will show you what years are compatible with each other.
Moon
