Old    Dan Allbagh (masterwake1122)      Join Date: Jul 2010       07-20-2010, 9:50 AM Reply
Took my 97 nautique sport out after I had the drive shaft pin put back in place.
Ran it for about 15 minutes or so and ran fine. Shut it down and decided to float for a while.
Went to go start it back up and it didn't do anything. Opened the engine compartment key on engine off and I could hear the low pressure fuel pump wind, the stereo was working, blower on, all guages worked (battery showed regular).
What gives? Starter cylinoid? Fuse? I don't get why it ran fine for a while and then nothing.... wasn't choppy water so it's not like it was bouncing around and some wires could have been jolted...
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       07-20-2010, 10:18 AM Reply
Neutral safety safety switch? They can be tender and the wiring would be vulnerable to collateral damage when one is massaging the drive line. If you have dash power but no click the issue will likely be found at the assist solenoid and / or neutral switch.
Follow yellow / red and black / yellow to your destiny.
Hope it helps.
Old    Dan Allbagh (masterwake1122)      Join Date: Jul 2010       07-21-2010, 1:30 PM Reply
I will check it out. Where would the assist sylinoid be and how would I check either of these to see if it's the problem? Thanks for the response.
Old    Dan Allbagh (masterwake1122)      Join Date: Jul 2010       07-23-2010, 12:00 PM Reply
I messed w/ the throttle and put it back to neutral and it started.... guess I will have to find out where that neutral safety switch / mechanism is to make sure it's okay.... hopefully it doesn't strand me again.
Old    Steven (stu929)      Join Date: Jun 2010       07-23-2010, 12:10 PM Reply
Mine is mounted on a valve cover. Im sure we do not have the same motor but I would look up top of the motor.
