Old     (4white)      Join Date: Apr 2010       07-19-2010, 6:37 PM Reply
I have recently purchased a Sanger V215 and have noticed a vibration when I pull up a rider. I am running 1800 -1900 pounds of ballast when I am am pulling a surfer and 2300 when I am pulling a wakeboarder. Has anyone else had this same problem or know what it is?
Old     (rallyart)      Join Date: Nov 2006       07-19-2010, 7:43 PM Reply
I had a shudder if I throttled up while on full lock in the steering. The dealer adjusted the rudder and it no longer does that, or vibrate at all.
Old     (westsiderippa)      Join Date: Dec 2006       07-19-2010, 9:26 PM Reply
most boats will have a little shutter when you give a little gas from idle with the wheel fully cranked. some boats will get a little vibration right out of the hole. next service get your shaft and strut aligned. also make sure your prop is perfect. just the smallest tiny little imperfection will give a vibration
Old     (wake_upppp)      Join Date: Nov 2003       07-19-2010, 9:31 PM Reply
Sounds like it's cavitating. Stock prop? Aftermarket prop installed/seated correctly? Vibration at any other time/speed? Need more info.
Old     (4white)      Join Date: Apr 2010       07-20-2010, 8:45 AM Reply
Hi Sparky
It is a stock prop, no vibration at any other time. Can you adjust cavitating?
Old     (wake_upppp)      Join Date: Nov 2003       07-20-2010, 10:28 AM Reply
Not really on that boat since it has a fixed ride plate for the most part. You only have a few degrees adjustment. But its at start up so probably not going to be able to get rid of it with plate adjustment. I would have the prop checked and also check runout on the shaft for starters. Having the engine alignment checked would be on my list as well.
