Old     (RobbieMWD)      Join Date: Apr 2010       07-14-2010, 10:23 AM Reply
Where can I get the adapter needed to replace my XM3 with a CMD6? I understand that the XM3 is bigger.
Old     (brit_rider)      Join Date: May 2004       07-14-2010, 12:58 PM Reply
I'm not positive but I think you are mistaken.
The units are both single Din but with larger fascias. If anything I'd have said the CMD6 is the bigger unit. Either way. the CMD6 should cover the hole and allow you to bolt it in so shouldn't be an issue.
If it were me I'd look towards the Fusion MS-IP600. I've been working with that stereo and its predessor for a few years now and do not believe there is a better unit on the market. it has independend zone control (so you can contorl sub, tower and in boat separately.. all with individual setup controls) and lets you slide an ipod or iPhone right inside. If its an iphone it'll ring through the speakers if someone calls too which is always useful on a noisy boat.
In over 100 units I think we've seen like 1-2 go bad... which is exceptional in our UK boating conditions.
Old     (evil0ne)      Join Date: Sep 2006       07-14-2010, 4:19 PM Reply
Well...I replaced a XMD3 to a CMD5 and the CMD5 is narrower by about a half inch. I left the 4 screw holes in my glovebox and called it a day. I'm assuming the CMD6 is similar.
Old     (david_e_m)      Join Date: Jul 2008       07-14-2010, 5:28 PM Reply
The CMDs are slightly taller but not as wide as the XMDs. This leaves the previous mounting screw holes just to the outside exposed. A conversion trimplate is available that conceals the holes.
David
Earmark Marine
