i just started landing this trick. it is actually easier than a backroll i think. if proper approach and edging is done, this trick basically happens on its own. i just take a progressive edge, making sure i edge all the way through the wake. once you feel the pop, simultaneously take your rear hand off the handle, throwing it up and back, and look straight back. make sure to keep your lead hand straight and don't pull in because the tighter line will help with the rotation. think of how you might throw your hand up when doing a back flip into a pool (it would make a 90 degree angle). you can also initiate this trick with a "trip" flip type of edge, but the other way seems to work better for me. hope this makes sense and helps. good luck.
