Old    Fill er up (fill_er_up)      Join Date: May 2006       07-08-2010, 3:59 PM Reply
I have a standard 6 speaker plus bazooka tube setup and generally only run it when the boat is running so figure I only need the one standard battery. It lives under a boathouse roof on a lift and I was looking for something that could just "top it off" between weekends. I've seen the cheapo "battery tender" going for less than $20 bucks but dont want to scrimp if its a fire hazard. Thoughts?
Old    Ken W (kenteck)      Join Date: Jan 2005       07-08-2010, 4:17 PM Reply
i got one of these....... works great: http://www.amazon.com/Marine-Xtreme-...630973&sr=1-14
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       07-08-2010, 4:22 PM Reply
I use a Pro Mariner ProSport 6.
Old    Fill er up (fill_er_up)      Join Date: May 2006       07-08-2010, 5:48 PM Reply
So it stays mounted to the battery in the boat and you connect the plug between uses?
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       07-08-2010, 6:16 PM Reply
Exactly. Mine is hooked to one battery but charges both through an Auto Combining Relay. You can buy one with as many battery banks as you need. Those Maintaners are not meant to charge up batteries, just to keap charged batteries charged.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       07-09-2010, 6:58 AM Reply
If your looking for a small charger/maintainer, you can't beat these. No reason to spend hundreds on chargers you really dont' need.
http://batterytender.com/
Old    wakemania (wakemania)      Join Date: Sep 2008       07-09-2010, 7:52 AM Reply
I use the 2 bank 10 amp one from bass pro. Had it for 3 years with no issues. Definately prolongs the battery life. I keep mine plugged in all the time while not in use. It has a float mode after it has been fully re-charged so it doesn't harm the battery.
http://www.basspro.com/webapp/wcs/st..._SearchResults
Old    SeaDawg (seadawg)      Join Date: Jan 2006       07-10-2010, 6:01 AM Reply
Do you guys remove or disconnect your batteries in the off season?
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       07-10-2010, 12:51 PM Reply
Nope, just leave then plugged in to the on-board charger.
