Old    A.J. West (you_da_man)      Join Date: Sep 2009       07-05-2010, 7:41 PM Reply
Saw this today after a 3 mile drive back to my boat storage unit. Anyone want to chime in on why one of my tires/axel is jammed up into the fender like that. I didn't hit any bumps, I didn't run off the road, didn't hit a curb or anything. The wheel rubbed the inside of the fender to the point of scortching the paint. Look at the pics.
Picture of the side that is normal
Rubbing side
Close up of rubbing
Good side underneath, everything is lined up correctly
Rubbing side, incorrectly lined up
Fender
Old    Brain Rinse (brainrinse)      Join Date: Aug 2007       07-05-2010, 8:05 PM Reply
Yeah, Boatmate knows about this issue. I can try to find you the details, but give them a call and they will make it right.
Old    Brain Rinse (brainrinse)      Join Date: Aug 2007       07-05-2010, 8:07 PM Reply
http://moomba.com/msgboard/showthread.php?t=9291
Old    mojo            07-05-2010, 8:10 PM Reply
off topic, where can i get that non-slip decking? good luck with the fix.
Old    A.J. West (you_da_man)      Join Date: Sep 2009       07-05-2010, 8:13 PM Reply
Thanks for the link...looks like that's my problem. I hope they can send my axel fast. I've had my boat only since 10 months.
Old    CORY MITCHELL (stang_killa_ss)      Join Date: Jan 2010       07-05-2010, 8:13 PM Reply
looks like you dont have leafs like i do AJ.
tortion setup.
Old    John Bauer (jonyb)      Join Date: Nov 2008       07-06-2010, 10:09 AM Reply
Those are torsion axles. Call Owen or Jerry at Boatmate. They'll do what they can to help you out.
Old    Brett Lockwood (Brett24ve)      Join Date: Mar 2010       07-06-2010, 10:24 AM Reply
while you wait for the new axle to arrive, you can remove the torsion arm and reset it back on the splines. Just move it 2-3 notches downward and that should do the trick. It isnt a permanent fix but will atleast allow you to somewhat safely move your boat. Any large bumps will cause it to slip again so drive careful.
Old    Cory D (cadunkle)      Join Date: Jul 2009       07-06-2010, 2:19 PM Reply
Looks like a snapped torsion bar to me, or a failed adjuster on the end of it.
Old    Tim (srock)      Join Date: Mar 2002       07-07-2010, 5:50 AM Reply
I had a similar problem with my boat mate trailer; my springs inverted a dropped the fender onto the tire. I've had broken leafs, leaking seals, boards that came off, rust under the walk pads. All on a trailer that is seldom used and on good roads, what junk.
