Remove the arm thats attached to the rudder, Put a pad or something soft on the prop guard. Take a hammer and block of wood and tap on the rudder shaft it should just drop down on the prop guard. Don't lose the woodruff key! It makes it alot easier if you remove the housing that is in the bilge, 4 bolts and its out. Now you can take the rudder and housing up to Napa or your choice of parts stores to get o-rings. Jus do reverse order to get it back in, put the rudder shaft up into the bilge and then install the housing. Pack the hell out of it with WATER PROOF grease other wise it will just wash out. Also get you some 3m 5200 for sealing up the housing area. It will take you longer to move your seats and other crap than to change the o-rings. Good luck if you do it.
