Old     (dirwoody)      Join Date: Apr 2003       06-21-2010, 1:07 PM Reply
Just can't put my finger on it. How do you guys weight an Epic for surfing?
Old     (Jdizzle78)      Join Date: May 2010       06-21-2010, 5:16 PM Reply
I just fill up the port and fill up the bow and run the trim tab at about 75percent, obviously it is the opposite if you ride starboard. if you run the tab at 100 percent it creates a curl and at 0 percent it flattens the wave and the bow rises really bad
Old     (themxercr85)      Join Date: Jul 2007       06-26-2010, 3:48 AM Reply
You'll need more then just the ballast, It takes a decent amount to make it lean. When I surf I fill full rear whichever side, full front, and as many ppl as I can get on the surf side. Normally I'll have my rear tower mount dragging in the water. Thats a big wake =D oh and I also throw the tab at about 75, and now Ive got port/stbrd tabs so Ill be using those as well.
