Old    Jay Smith (snoopy1173)      Join Date: May 2010       06-22-2010, 5:30 PM Reply
ok so in the middle of the board there is a crack. Its right on the bottom of the board. Its about 8 inches long, in the direction of one side of the board to the other. (Heel to toe directed). Now how do I fix it so it is strong and rigid. Not just epoxy it so its sealed. Is there a sealer that will fill in the crack itself? Hopefully planning on still using it as a slider board. Help....anyone have any experience with this kind of thing?
Old    Jay Smith (snoopy1173)      Join Date: May 2010       06-22-2010, 5:31 PM Reply
maybe description was confusing, the crack id in the very middle of the board, on the bottom . It is a straight line from the heel side to the toe side. Slingshot reflex
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       06-22-2010, 6:20 PM Reply
Toast
Old    Jay Smith (snoopy1173)      Join Date: May 2010       06-22-2010, 6:40 PM Reply
ahhh but the crack isnt even thick its just like i said about 8 in in length and is less depth than a binding hole insert on the top of the board
Old    Jeremy (wake77)      Join Date: Jan 2009       06-22-2010, 6:46 PM Reply
Kiss it goodbye
Old    ScottRobinson            06-22-2010, 6:50 PM Reply
I agree you are toast man. You can try some temp solutions but one hit and you are done. Sorry wish it wasn't so. Check on the warranty, maybe you can get a new one from them.
Old    Small Light (stephan)      Join Date: Nov 2002       06-22-2010, 6:50 PM Reply
Just ride it as a slider board and when it disintegrates don't be too surprised. You can seal it but there is nothing that can bring back the strength once the glass is compromised.
Old    Andy Nintzel-NautiCurl Wake Shaper (andy_nintzel)      Join Date: Sep 2004       06-22-2010, 7:17 PM Reply
yeah she is fried. One of two things happened either you crack the top sheet, the foam core, or both, guess that means one of three things happened. Either way it done. I would not suggest using it as a rail board if it snaps completely in half you could get wasted pretty bad. Hang it on the wall, its a war story.
