Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       06-18-2010, 4:59 PM Reply
Installing a in line fuel filter and not sure what kind of thread sealer to use on the fittings. What do you use? Thanks for the help.
Old    Derek (camassanger)      Join Date: Oct 2009       06-18-2010, 5:55 PM Reply
there is an oil/gas resistant teflon tape that I have used. It is yellow. any hardward store would have it.
Old    Art (rallyart)      Join Date: Nov 2006       06-20-2010, 10:59 PM Reply
Most fuel filters are bevelled fittings with straight threads. If it is a pipe thread tapered fitting use teflon tape. If it is a compression or taper fitting the seal is made with the fitting shape not the threads and they should not be sealed.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       06-21-2010, 6:33 AM Reply
Avoid Teflon tape, especially when using NPT fittings in aluminum housings for fear of cracks. Tape sucks anyway. For fuel use Permatex #1 on fittings and #2 on gaskets like the tank sender. (auto-parts store) For water use Rector seal #5 (hardware store)
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       06-21-2010, 11:38 AM Reply
Thanks, I used permatex thread sealer, and looks like my leak has stopped. Thanks for the info all!
