Old    Kiley Hughes (mrboston187)      Join Date: Jul 2008       06-17-2010, 4:37 PM Reply
I took a fall today ripping my binding off the board, wrecking the threads on the inserts and bending my baseplate a little. I fixed the threads with a tap, andmy base plate is only slightly bent. Its for an '07 Ronix Frontier boot. its not bad enough to send in (in my opinion) , Im thinking I can just bend it back myself, anyone ever done this?
Old    Ryan Cowan (aces6692)      Join Date: Nov 2006       06-17-2010, 7:37 PM Reply
damn bro, that must have been a pretty bad fall, i would just send it in, that way it should be covered under warranty and it wouldnt be tampered with, you never know what can void a warranty these days haha.
Old    Dan (texastbird)      Join Date: May 2003       06-18-2010, 10:42 AM Reply
Everytime I have ever seen damage like that it was because the hardware wasn't tight. Just sayin..
Old    Andy Nintzel-NautiCurl Wake Shaper (andy_nintzel)      Join Date: Sep 2004       06-18-2010, 2:49 PM Reply
Dan is speaking the truth, gotta tighten those bolt before ever run.
When Obrien bindings used have Aluminum base plates I would do this all the time, just bend it back as best your can and you should be fine.
Old    Kiley Hughes (mrboston187)      Join Date: Jul 2008       06-18-2010, 4:15 PM Reply
it was definitley because the screws werent tight! we couldnt find the screwdriver, so i tightened them with the boat key, dont ever do that! I just put the plate in the vice and gave her hell, it is only slightly bent
