Old     (typhoon)      Join Date: Jul 2001       06-14-2010, 3:58 PM Reply
For the frton ballast in the floor where is the best place to run the drain/overflow line? I was thinking about drilling a hole in the floor close to the air vent by the driver's side so it would drain out the side of the boat more or less by the driver's right knee.
Thank you
Old     (ralph)      Join Date: Apr 2002       06-14-2010, 4:07 PM Reply
You can route the hose behind the driver foot panel, follow the steering cable out of the locker to up under the dash. I would put the outlet under the rub rail below the windscreen, so yes just forward of your right knee
Old     (typhoon)      Join Date: Jul 2001       06-16-2010, 8:08 PM Reply
Hey darren, how are things?
Is there a place to run it up or do I have to drill a hole in the floor?
Old     (ralph)      Join Date: Apr 2002       06-16-2010, 8:13 PM Reply
Doing well buddy!
There is a 4" hole already there, currently the steering cable runs through there + the heater lines if you have the heater.
Old     (typhoon)      Join Date: Jul 2001       06-16-2010, 9:31 PM Reply
awesome. i will check it out.
thanks
