Old    Peace (ALWakePEACE)      Join Date: Jun 2010       06-16-2010, 9:38 AM Reply
I picked up the 2010 Watson Hybrid yesterday and my boots are being shipped off on warranty.. I have an older pair (2007 maybe??) LF Watsons and they fit on the board fine, but I was just wondering if anyone else has this board and has put any other bindings on it from other companies?
Old    Spencer (spencerwm)      Join Date: Feb 2009       06-16-2010, 11:00 AM Reply
I have put a pair of 2010 Ronix One boots on my Hybrid before my LTD Watson's came in. The board is sick. You are going to love it.
Old    Jeremy (wake77)      Join Date: Jan 2009       06-16-2010, 11:14 AM Reply
I ordered the 09 Cells and a Hybrid, there is someone else on this board with the same setup, but something ended up happening with my order, so I had to get the Vibe instead. As long as the boots have the six inch plate, you should be fine without having to use adaptors.
Old     (Eden)      Join Date: Jul 2010       07-06-2010, 2:25 AM Reply
ronix uses longer screws than LF... and since the Hybrid is a thinner board, you cant use RONIX screws if you are using the WIDEST setting... the other 2 settings are fine however...
Old    Jon Doe (Kane)      Join Date: Mar 2010       07-06-2010, 2:47 AM Reply
Eden, you could just cut the screws a bit shorter, then they'll be fine
Old    Jason (jason95gt)      Join Date: May 2006       07-06-2010, 7:00 AM Reply
Or just put washers between the screw and the adapter piece.
Old     (Gears)      Join Date: May 2010       07-06-2010, 6:28 PM Reply
I put 09 cells on my FLX and had to snip about 3mm off them.
Old     (Eden)      Join Date: Jul 2010       07-08-2010, 7:11 AM Reply
yeah, i concur... with the cutting and the washers... all that will work...
What size board did you get? and how tall are you? Im just curious how wide most people have their binding setup...
im 5'11 and im using the middle setting for my hybrid 139...
Old    Dan (texastbird)      Join Date: May 2003       07-08-2010, 6:10 PM Reply
I demo'd the Watson Hybrid with a pair of '10 Ultras. Those bindings have awesome flex and still feel like they are holding my feet securely.
