Old    DKidneyBean (DKidneyBean)      Join Date: May 2010       06-09-2010, 2:37 PM Reply
Where is the best place to purchase a 2 Bank Battery Charger/Tender to keep the batteries charged when the boat is not in use?
Does anyone have a 2 battery setup and charge them separately when the boat is not in use?
Thanks.
Old    Jonathan B (espritv8)      Join Date: Dec 2009       06-09-2010, 4:16 PM Reply
You can get the prosport 2 bank charger for less than 100$ on ebay. Got one, and works good so far...
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       06-09-2010, 5:09 PM Reply
The pro mariner unit will work well. Go ahead and get a two bank.
I am going to assume that you have a starting battery and a reserve battery that are seperated by a perko or blue sea switch. If this is the case, get the two bank and charge them seperately with the battery switch in the off position.
Don't just use the charger in the off season...keep your batteries hooked up at all times when not on the water. This will give you maximum battery life and performance.
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       06-09-2010, 5:51 PM Reply
I use a single bank ProMariner that charges two batteries through an Auto Combining Relay.
Old    Randy (dudeman)      Join Date: Mar 2005       06-10-2010, 9:42 AM Reply
I use this and haven't had a problem with it yet.
Old     (jason99ta)      Join Date: May 2010       06-10-2010, 11:22 AM Reply
This is the same one I use on my '03 X-2. Works great.
Old    Mikeski (mikeski)      Join Date: Aug 2003       06-10-2010, 1:33 PM Reply
Ajholt, which one do you use, what is the amp rating?
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       06-10-2010, 7:36 PM Reply
This one. http://www.pmariner.com/productFeatu...m=42006&page=2
It works great. I don't have to have a super fast charger like some people do though.
Old     (tro)      Join Date: May 2009       06-10-2010, 8:42 PM Reply
I have a 2 bank Dual Pro Sportsman Series - works like a champ
http://www.dualpro.com/media/pdf/SS2b%20insert.pdf
Old    Ray M (wakeborder5)      Join Date: Jun 2002       06-11-2010, 7:59 AM Reply
Will the 8 amp one work fine? I don't need a super fast charge, my boat stays on a hoist and we don't go out more than 2 hours a day.
Will these work fine on any type of battery? I believe mine are fairly standard batteries...maybe dual purpose?
Also, my batteries are in the two back corners of the boat, would these chargers come with enough wire or no? If not, how much would the wiring cost?
These are pretty easy to wire I assume, just positive and negatives and then the 12v plug in will stay in the compartment until plugged in?
How does this one look? I found it online and won't have to pay shipping since it's within driving distance http://www.jandhproducts.com/_e/Prom...HD_CHARGER.htm
