Old    SANGeRIA (sangeria)      Join Date: Dec 2003       06-09-2010, 9:11 PM Reply
I bought a brand new Sony 540UI to replace my old Sony deck that crapped out. Problem is, at high volumes the sound cuts out. I wired it up just like the old one was since it was the same make...but I'm wondering if I'm missing a setting somewhere. This thing is way more advanced than what it replaced...but I'm wondering if that's a good or bad thing. Any help would be appreciated.
Old    Ash (stuntmonkey)      Join Date: Feb 2009       06-09-2010, 10:30 PM Reply
Are you running the speakers straight off the headunit or do you have an amp in there. Either way your hitting your peak power load for the volume.
Old    SANGeRIA (sangeria)      Join Date: Dec 2003       06-09-2010, 10:41 PM Reply
I have an amp. Just curious if there is a setting I need to change on the headunit since I am running an amp. You can tell I have no idea what I'm doing...just plugged things in the way they were on the old one.
Old    Bruizza (bruizza)      Join Date: May 2009       06-10-2010, 8:08 AM Reply
is your amp overheating and going into protect mode? Your amp is obviously working the hardest at high volume. If it gets too hot it goes into protect mode and shuts down.
