Old     (brownman)      Join Date: Jun 2007       06-06-2010, 10:18 PM Reply
Break out the boat this year and the Perfect Pass screen is malfunctioning. Sometimes I get garbled gibberish, other times screen goes inverted like in these photos. Most of the time it goes crazy then completely blank. It still engages and runs fine, i just cant read the screen. I've done a system reset, has anyone ever seen anything like this happen before? Is there a quick fix or should I plan to replace?
Old     (slidin_out)      Join Date: Apr 2010       06-07-2010, 6:47 AM Reply
probably just need a new disply, call up the PP people and tell them what's going, i can almost guarantee they will quickly diagnose it for you
Old     (airagain)      Join Date: Jun 2006       06-07-2010, 1:05 PM Reply
Mine was doing similar things. Turned out the connection of one of the wires, at the wiring harness, where it enters the back of the display, had come loose. It works fine now.
Old     (dhcomp1)      Join Date: Mar 2010       06-09-2010, 9:24 AM Reply
Disconnect/reconnect all your display connections. My 08's does that occasionally, normally lose connection. A little dielectric grease on the connectors never hurt either.
Shouldn't need a new display.
Old     (blowhole)      Join Date: Nov 2009       06-09-2010, 10:55 AM Reply
not to hijack back my buttons wont work on my display. could this be due to loose wires? everything else shows up fine including speed.
Old     (brownman)      Join Date: Jun 2007       07-09-2010, 6:09 PM Reply
Sorry it took so long to respond DH. Thanks for the advice. Disconnected and reconnected the system right at the harness in the engine compartment. Worked like a charm! I'm back in business, thanks bro.
Old     (camassanger)      Join Date: Oct 2009       07-09-2010, 7:01 PM Reply
Great thread here gents. I have a similar problem and was going to start a post, but I think I will try the wires first. My problem is that the display cuts out completely, but PP still controls speed just fine.
Also, I noticed that when i turn the heater on it resets PP. Any ideas for that?
Old     (duffymahoney)      Join Date: Sep 2008       07-09-2010, 7:30 PM Reply
Voltage drop would cause the screen to turn off. My old boat did that, I ran a new + and - from the battery to the fuse panel, worked perfectly after that.
Old     (texastbird)      Join Date: May 2003       07-10-2010, 7:47 AM Reply
+1 on the dielectric grease. Good preventative.
