Old    Edgar Ramon (jame04)      Join Date: Nov 2007       06-06-2010, 9:58 AM Reply
It has a good wake but wondering what you guys that Enzo them use for additional ballast. One thing is it does not have a front KGB stock so should we add weight up front?
Old    Show (bigshow)      Join Date: Feb 2005       06-06-2010, 10:52 AM Reply
Words say wrong you backwards all.
Old    Edgar Ramon (jame04)      Join Date: Nov 2007       06-06-2010, 11:00 AM Reply
that was helpful
It is a 23 Enzo
Old    Harold Hemming (h20king)      Join Date: Dec 2009       06-06-2010, 12:21 PM Reply
there is a ton of info at www.centurioncrew.com
Old    Show (bigshow)      Join Date: Feb 2005       06-06-2010, 2:28 PM Reply
Two words " Ezno Sack". That's all you need for surfing. 2x on Centurion Crew.
Old    Edgar Ramon (jame04)      Join Date: Nov 2007       06-06-2010, 4:39 PM Reply
its not my boat so just helping a friend. do the stock tanks need to come out for the sacks?
Old    jkw (lakesurfer)      Join Date: Jul 2009       06-06-2010, 5:36 PM Reply
Edgar
1. Take out the rear and mid hard tanks and plug in 1,500lb Enzo sacs on each side (it is plug and play. If you have the mid tanks make sure there are two in/outs/over flows. If not have them install them so you can fill with both the rear and mid tank plumbing). This will give a nice wave. If you want it bigger add weight to the seat and a little weight to the nose. I know a few guys that run 300lbs in the opposite rear tank. They say it add a lot of push to the wave.
3. If you are running on the regular side, run with the wake plate level with the transom. If you are running on the goofy side, run with the wake plate all of the way down (you will need a trim tab or Switch Blade to clean up the goofy wake on Enzo)
2. go to www.centurioncrew.com. Very helpful site and the question has been answered in detail
Good Luck!
Old    JS (dreamer)      Join Date: Nov 2008       06-07-2010, 9:06 AM Reply
If you want the bare minimum, throw a 750# sac in the surf side locker, then another 750# sac on the surf side seat and ride between 10 and 11mph. A large person on the surf side locker helps as well.
