Old    HYPO (hypo303)      Join Date: Jun 2004       06-05-2010, 9:00 PM Reply
My 1990 Malibu skier,mercruiser 5.7 starts great at first ,then runs fine,when i shut it down,it have problems restarting,i gave it a tune up with new points,etc...
dont know where to look next ...
i read some forums that said sparkplug wires can do this,and maybe a carb problem
and suggestions would be appreciated
thank u
hypo
by the way the boat runs great ,its just a starting issue after i drive it for a while
Old    Nick (ironcross25)      Join Date: Jul 2006       06-06-2010, 7:27 AM Reply
Ive been dealing with the same problem on my 86 supra. I went thru the alternator, starter, coil, battery. Now I am doing plugs, wires, cap, rotor, battery cables. Ill let you know what I find. My main issue is running for a while then whe I stop and kill the motor then go to restart it acts as if the battery is dead, then it fires right up.
Old    Trace (trace)      Join Date: Feb 2002       06-06-2010, 7:36 AM Reply
I had the HEI module go out on a Camaro I had that caused this syptom. The coil and anything with a circuit board (which is probably nothing on boats of this vintage) are suspect for problems after warmup. Fresh spark plug wires are always good. Check the battery cable, too.
Old    HYPO (hypo303)      Join Date: Jun 2004       06-06-2010, 11:42 AM Reply
just bought some new wires,they should be in sometime this week,ill let you know
Old    Tyler Rupp (hoochyglidaa)      Join Date: May 2010       06-06-2010, 12:04 PM Reply
I had the same issue on my 98 Mobius. Had the carb rebuilt and solved the issue as far as I know.
