I would like to respectfully disagree with the above opinions and suggest you go with the One. I ride an Ibex, and the first time I rode it behind a real wakeboard boat I had trouble just hanging on. I'm by no means an advanced rider, but at the time I had wake to wakes (TS and HS) and a couple 180s dialed behind my I/O. The pop of the board was great for the smaller wake, but took a lot of getting used to behind a bigger boat. The Ibex is quite a bit bigger than your current boat, which means it will ride higher in the water, but I think the change might be a bit of a shock, especially with the different rocker styles. Demo if you can, but my suggestion is the One. You can't go wrong either way, but I think you would have more fun, sooner, on the One. Happy shredding.
