Old     (blondesrule)      Join Date: Aug 2007       06-02-2010, 9:30 AM Reply
I currently have a 2005 Supra 21V. It has approximately 2000lbs of ballast, lead and water. Would like to go to lower pitch prop, but can't afford to spend the $500 on an acme 1235. Is a prop pitched at 13x15.5 or 13x11.5 good enough, or will this not get me the whole shot I am looking for? Any help would be appreciated.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       06-02-2010, 6:46 PM Reply
Cant you compare the above specs with the Acme 1235 specs and see where you're at? Just thinking out loud.
Old    Sippi (sippi)      Join Date: Dec 2007       06-03-2010, 8:46 AM Reply
Correct me if I'm wrong but I think you can change the pitch (the 2nd number) but not the size(1st number) the acme 1235 is a 14.5x14.25. I don't know what your stock prop is but your probably going to want to stay with the same size and change the pitch to a lower number to get a better hole shot. So either the props you listed or the 1235 wouldn't work. Depends on your current prop.
Old    adam (03suprassv)      Join Date: Jan 2009       06-03-2010, 9:48 AM Reply
I have a supra 22ssv and just went from a 14x18 to a 14.25x14.5 and with 2000lbs of ballast and 8-10 people it comes out of the hole strong. THe 14x18 just didnt have enough low end to pull out. I dont think you will have a problem. Just make sure the extra size will clear your trailer.
