Old    Jaak (vguy75)      Join Date: Feb 2008       05-27-2010, 4:00 PM Reply
Anyone know if Line-X is compatible with 3M 4200 marine sealant?
I'm going to Line-X my fiberglass swim platform on my '79 Mastercraft and want to seal it with 4200, but the local Line-X rep isn't sure if it will stick or not. The platform is going to be a combo of thru-bolted and/or lag screwed with 9 screws/bolts, so that in itself should be good, but I 250+, so I'm after something with some adhesiveness too.
Any thoughts on going with the UV Sealer vs w/o?
I kind of like more of a matte look as my boat has a matte rub rail and trim, but wasn't sure if it grey out over time. A few of the Line-X threads on here indicate that it still looks fine after a couple years, but they're older threads so I figured I'd ask again.
Thanks!
Old    Jaak (vguy75)      Join Date: Feb 2008       05-27-2010, 4:01 PM Reply
Sorry, should have wrote, want to seal the holes and the surface between the platform and the transom as it was done from the factory.
Old    Craig Glass (my_malibu)      Join Date: Feb 2008       05-31-2010, 3:19 PM Reply
yes
just make sure the 4200 is cured
