Old    Dan (goatboy)      Join Date: Apr 2010       05-26-2010, 9:23 AM Reply
So the weather has taken an unexpected turn for the better for a few days in the UK and the water temps at my local cable have rocketed, I'm not feeling man enough to go just boardies and vest yet so I was going to invest in a shortie (shorty?) wetsuit, but I'm not sure what to get.
For my winter suit I wear an O'neil pyshco II which is fantastic but I wasn't sure if its worth just getting a real cheap 30 ($40) shorty or if I should spend a bit more 60+ ($80-$100) and get something a bit more serious.
It makes sense to spend a lot on a winter suit so you get good seals and seams but I'm not sure it matters so much for something for the summer....
Any thoughts anyone
Alternatively I could just grow some and get out there without a wetsuit...
Old    Small Light (stephan)      Join Date: Nov 2002       05-26-2010, 10:20 AM Reply
I wanted a long sleeve spring for awhile and finally got one this past fall. I went to a large surfshop and tried on every one they had. Each felt a little different and I ended up with the O'neill Gooru L/S Spring. I'd suggest spending a little more, especially if you will use it frequently. I've used it a ton this year and it is the most comfortable thing I've ever worn. I still use it in the summer for the early AM dawn patrol sets, its awesome.
I bought it cuz I could never really stand just a heater shirt, I mean if I'm going to wear something, might as well protect the nuts a little bit while I'm at it. While looking cool isn't the most important thing, I'd recommend a long sleeve over a short sleeve.
Old    AtTheLake (bmartin)      Join Date: Jan 2007       05-26-2010, 10:39 AM Reply
I have been using a $40 3/2 shorty by Oneil for years and it gets the job done. I usually wear a rash guard underneath for a little extra comfort.
Old    Dan (goatboy)      Join Date: Apr 2010       05-27-2010, 1:12 AM Reply
Cheers guys, looks like I need to do some shopping!
Old    CIREboardshorts.com (nuckledragger)      Join Date: Jun 2004       05-27-2010, 6:39 AM Reply
Spend a little extra dough. It never hurts to have a good wetsuit. If it gives you some extra time in the water, its definitely worth it.
Old    Dan (goatboy)      Join Date: Apr 2010       05-27-2010, 8:28 AM Reply
Well I went for a Mid range suit, blind stitched and glued seams, so hopefully it will be OK.
allegedly half price at 50 ($70) Should be better than the $40 suits I was thinking about....
Thanks for all your advice!
