Old     (blowhole)      Join Date: Nov 2009       05-24-2010, 8:05 PM Reply
I got perfectpass with paddle wheel. The display is working showing speed and what I want it to run at. But I cant get it to go from off to on. The button wont work, I hold it down i press it once nothing. Am i missing something? Do i have to unwind it before it can work?
Old     (blowhole)      Join Date: Nov 2009       05-25-2010, 7:31 AM Reply
by unwinding i mean lifting the engine cover and turning that dial that has the cable wraped around it.....
Old     (ryanw209)      Join Date: Jan 2010       05-25-2010, 7:37 AM Reply
sounds to me like the on/off button is jacked. I've heard of the buttons not working a few times on here. Call up PP and tell them the situation. I just got mine fixed.
Old     (blowhole)      Join Date: Nov 2009       05-25-2010, 7:59 AM Reply
F this is seriously the second time i used it since i got the boat, which is an 04 dont know if it came with it or was an add on. thanks for the response though
Old     (mlb75)      Join Date: Aug 2007       05-27-2010, 8:19 AM Reply
if its only been used a couple times since 04 that may be part of the problem, generally things don't like to sit for that long. From what I've heard though if you call up the folks at PP they can probably get you going again.
