Old    Derrick Dilworth (ricta)      Join Date: Nov 2006       05-21-2010, 3:03 PM Reply
Other then the simple less cut and slower approach to the wake, is there any tricks you guys use to still take your back roll huge and not over rotate?? Had someone tell me to move the handle out past my front hip but can seem to make my mind do that in the air.
Thanks for any suggestions
Old    A-dub (behindtheboat)      Join Date: Aug 2006       05-21-2010, 3:24 PM Reply
You let the handle out to slow down and spot your landing. Or just take it to revert
Old    Morgan Wright (morgs_dirtwakesnow)      Join Date: May 2010       05-30-2010, 8:07 PM Reply
To slow down your rotation keep both hands on the handle for as long as possible. When you take your backhand off the handle, your body squares up and you begin to spin faster, keeping both hands on will slow your rotation down. hope this helps
Old     (will5150)      Join Date: Oct 2002       06-03-2010, 1:40 PM Reply
Think about taking the trick staight up and keep the handle low. Also- Get really laid out- if you tuck your knees, you'll spin faster. Also keep the handle on your lead hip- that will really help.
