Old    Swatguy (xstarrider)      Join Date: Jun 2007       05-19-2010, 8:48 AM Reply
I am going to help a buddy install a Monster Tower on his older MC. Anybody got any tips to help the install go smooth? We have tape, new sharp bits, and 4 guys to help.
We are going to try and keep all 4 mounts on the top deck side as I think that is best as most boats with newer towers have moved to top deck mounts,. Just not sure if the gunwale itself is wide enough for the bracket so we may have to go to the side mounts in the rear, but I am hoping it is.
Old    Scott Murphy (muurph84)      Join Date: May 2010       05-19-2010, 1:12 PM Reply
just follow the directions that came with it or you can download them from the website. measure 5 times drill once, it should be very easy with 4 people i got mine on in about 3 hours with the help of my neighbor
Old    J D (jeff_mn)      Join Date: Jul 2009       05-19-2010, 4:04 PM Reply
its pretty simply. I made 1" x 6" wood brackets on the underside of the hull to spread out the pressure on the fibgerglass. also, when you drill, run it in reverse. it will make a cleaner hole in the glass with no chipping.
