Old    Steve Amestoy (stevev210)      Join Date: Feb 2005       05-17-2010, 8:27 PM Reply
Has anyone else had problems with the bag leaking between the GHT adapter and the valve on the sac? I use the flyhigh pump to fill a straight line 350 with the spring loaded valves, i bought the 3/4 GHT adapter which allows me to fill the sac but when i twist it into place and strart the pump water leaks out between the adapter and the valve on the sac. Maybe i got a faulty GHT adapter?
Old    Ryan Bush (ryanbush11)      Join Date: May 2003       05-18-2010, 7:49 AM Reply
I have the same problem trying to use the adapter to fill them with a Tsunami Pump, i guess its just normal
Old    Spencer (spencerwm)      Join Date: Feb 2009       05-18-2010, 1:09 PM Reply
It is normal. They just don't work as well as they should. I am even getting a little bit of water leaking out when using the new Sumo Pump with the launch pad sac.
