Old     (redm1496)      Join Date: Jun 2010       06-02-2010, 3:56 PM Reply
i appreciate your help. would that change how i wire them? why is it better to be at 4 ohm?
Old    TigeMike (chpthril)      Join Date: Oct 2007       06-02-2010, 4:22 PM Reply
How are they wired now You have one pair, correct? If they are already wired on the tower in parallel at the speakers and you only have one speaker wire running down to where the amp will be, then your choices are: a full-range mono or rewire them.
I'm referring to keeping the amp at 4 Ohm by having one speaker p/chnl. Bridging a 4 chnl amp down to 2 chnls with a pair of 4 ohm speakers will have the amp "seeing" 2 ohms on all 4 chnls. This equals more heat being generated and more power consumption. The 30 watts x 2 diggerence between the 650.4 bridged and the 850.2 @ 4 Ohm, IMO, is not worth it.
Old     (redm1496)      Join Date: Jun 2010       06-02-2010, 4:24 PM Reply
they are still sitting in the box. i'm just trying to think ahead.
Old     (redm1496)      Join Date: Jun 2010       06-02-2010, 4:27 PM Reply
so i can get the kicker zx850.2 for $300. unless someone can suggest something better for a similar price or something just as good for cheaper i think i may have to buy it in the next couple days. i'm trying to get everything together and ready for the 4th.
Old     (redm1496)      Join Date: Jun 2010       06-02-2010, 5:23 PM Reply
and i guess i will ask the question if the zx850.2 for $300 is worth it over the hifonics zxi-1010 for $185? i know what duffy would say
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       06-02-2010, 6:25 PM Reply
lol There are tons of great amps out there.
Old    Tyler Smith (smitty1258)      Join Date: Jun 2009       06-03-2010, 5:54 AM Reply
the speaker can issue I was referring to earlier in the thread was taken care of by Ken before the Memorial Day Holiday! I just sent him an email, and he got new cans shipped out to me ASAP and I was able to use the new cans for this past weekend!
New cans looks great, and I dont foresee an issues with this set. Im guessing I just happened to get a bad set because he had never heard of the issue I was having.
Old    Harold Hemming (h20king)      Join Date: Dec 2009       06-04-2010, 8:52 AM Reply
I am ruining three power acoustics amps they were cheap but put out lots of power I am very happy with them I am ruining all three at 4 ohms and have had zero problems and my system sounds amazing and with the cash I saved I was able to do other mods that made the boat perform better
Old     (redm1496)      Join Date: Jun 2010       06-04-2010, 2:35 PM Reply
well bought the zx850.2 so hopefully they will have a good sound to them. next step, wiring!
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       06-06-2010, 3:19 PM Reply
Got em up. They sound great.
Old    Justin (newmy79)      Join Date: Jun 2005       06-17-2010, 8:03 PM Reply
why can I see some of the pics posted in threads and not others....damn it!! Any other close ups of those cans AJ? I'm "browsing" (loose term) for a tower speaker set up and cannot afford WS or NVS so I was looking at the Krypt 8" HLCD's just based off some threads I found on WW to see if I could do it for a reasonable cost. I really like the black cans I found while browsing onlyinboards. I'd like to see some more of these setups. cans and amp setups.
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       06-17-2010, 8:29 PM Reply
I'll try to get some more pics.
Old    Ian Ashton (ian_ashton)      Join Date: Jul 2008       06-18-2010, 8:31 AM Reply
I'm trying to post pics of mine but I keep getting 'Upload failed' message. They are sized to 800x600, 125kb file sizes...
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       06-18-2010, 8:54 AM Reply
The easiest way is to upload them to photobucket.com, and then copy the image code. No resizing needed then.
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       06-18-2010, 9:13 AM Reply
If you have xp or windows 7 just download microsoft image resizer. Then you can right click on any picture or group of pictures and resize quickly and easily.
Old    Ian Ashton (ian_ashton)      Join Date: Jul 2008       06-18-2010, 11:16 AM Reply
Not sure if this will work, but I uploaded them on the Moomba forum. I can't get to Photobucket while at work.
Instead of using the standard clamps I decided to try something different; I drilled and tapped the horizontal cross-bar on my tower, and bolted the can bracket directly to the tower. I have a star washer between the tower and the can, and a lock waster on the head of the Grade 8 bolt. So far they seem really stable, actually alot more than I expected.
1 up, about to mount the other side:
SpeakerSox'd up!
Old    David Williams (wakeworld)      Join Date: Jan 1997       08-13-2010, 9:01 AM Reply
Ian, those photos should load fine. Send them to me and I'll take a look and figure out the problem.
Old    Jeff D (Jeff)      Join Date: May 2010       08-13-2010, 3:31 PM Reply
I see the 8" Krypts going for really reasonable prices on eBay ($200-250) but I never see the 6.5" ones up there. I'd rather not have to deal with 8" cans if avoidable being that the 6.5s are so much easier to find or build out of PVC.
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-13-2010, 4:27 PM Reply
For those of you who are running the krypt 6.5s are you pointing them directly back or slightly turned off to the sides? I have mine pointed straight back and I loose all sound when I"m in the flats and I can barely here them when I'm right behind the boat. Do you think this is a wattage problem? I know I'm not running a ton of power to them but I'm not sure if I can stand them being any louder while I'm in the boat! I'm planning on putting some sound deadening material inside the cans to help deaden the sound directly down to the driver and maybe direct it back to the guy on the rope.
I'm a bit baffled on why everyone loves these speakers but I can't seem to hear them very well. Whey the volume is up high enough to hear on the end of the rope how loud is in in the boat??
Old    Jeff D (Jeff)      Join Date: May 2010       08-13-2010, 4:38 PM Reply
Hmmm..... That's the biggest appeal of the HLCDs for me. I'm not into painfully loud music. I was hoping to make the sound audible at wakeboarding distance without deafening everyone in the boat. If that's not what these are capable of doing for me then I might just not have tower speakers.
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-13-2010, 4:45 PM Reply
Jeff,
I would seriously consider riding with someone that has towe speakers. I literally have to yell to the guy sitting next to me in the boat when I have the volume turned up loud enough for the rider to hear.
anyone else care to chime in?
Old    Jeff D (Jeff)      Join Date: May 2010       08-13-2010, 5:38 PM Reply
Originally Posted by corbin View Post
Jeff,
And that's with HLCDs?
And do you have independent volume control for your tower speakers?
Old    Tyler Smith (smitty1258)      Join Date: Jun 2009       08-13-2010, 8:45 PM Reply
Jeff,
same for me. I have the ws-420 as well. The HLCDs are LOUD!
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       08-13-2010, 10:13 PM Reply
Jeff,
See my pics above. My 8" krypts are mounted on the rear bar of my tower and above my Bimini. When I fade the music to the tower speakers the rider can hear them perfectly and it is very mild to the people in the boat.
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-13-2010, 10:27 PM Reply
Jeff,
Yes I have independant volume control in two ways. The first is they are on thier own amp so I can turn the amp gain to whatever level I want. The second is that my tower speakers are running off of the front set of preamp out puts and my boat speakers are running off of the rear set of amp speakers. Typically I just turn the fade so that it is all tower speakers because with just a little signal to the boat speakers when it is turned up it's too loud in the boat. I just simply use the tower speakers for all of the sound.
This is exactly what I am trying to avoid. I am thinking that putting some sound deadening material inside of the cans might help reduce the music inside of the boat coming from the tower speakers and allow me to listen to the boat speakers at a normal level.
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-13-2010, 10:29 PM Reply
ajholt-
How high are your tower speakers? Do you fade everytime a rider is on the line, or do you keep the fade somewhere centerline so that the boat passengers listen to the boat's speakers while the boarder listens to the tower speakers?
Old    Ajholt7 (ajholt7)      Join Date: Apr 2009       08-13-2010, 11:16 PM Reply
You can see in my pic above they are pretty high. When someone is riding I usually have them faded about 3/4 to the tower. If I have people in the boat that are not into loud music I fade them fully to the tower. I find that I really don't have to turn them up all that loud for the rider to hear them. Maybe that is the big difference between the 8" and the 6.5".
Old    Harold Hemming (h20king)      Join Date: Dec 2009       08-14-2010, 8:16 AM Reply
I have the 6.5 hlcd's and they rock they require lots of power I am pushing mine with 150 watts RMS each line the bottom of the cans with deadbeat this will help keep the sound up and out of the cabin
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-14-2010, 7:19 PM Reply
harold,
I saw your pics in another thread and have been looking for a few days trying to find "deadbeat." Do you know where I can find it? Is it the same thing as Dynamat?
Is there an off brand to Dynamat that would work in this application, that might be a little cheaper or work better? Essentially I want to eliminate as much sound in the boat coming from the tower speakers.
Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       08-14-2010, 7:53 PM Reply
What do y'all think of Soundstream? I have one of their amps in my truck and I like it but it is running a sub so I can't really speak the sound quality...
Old    Harold Hemming (h20king)      Join Date: Dec 2009       08-16-2010, 6:45 AM Reply
Corbin the dead beat is something I had lying around at the shop from old car installs but works great in keeping the sound up where it belongs.I think dynamat is quite similar and should work just as well
Old    Cyle Coatney (01centurion)      Join Date: Jun 2010       08-16-2010, 4:19 PM Reply
Where are u getting the cans for the 8in speakers? Looked but I can't find them
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       08-16-2010, 5:40 PM Reply
They used to sell them on boardersmall. Also sometimes on ebay. Or from Krypt.
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       08-16-2010, 5:42 PM Reply
Also samson sports sells a swivel 8" can.
Old    Tyler Smith (smitty1258)      Join Date: Jun 2009       08-16-2010, 6:47 PM Reply
They work but you have to drill out new holes, no biggie.
