So I recently moved up from a I/O to 2008 Sanger 210.
The one issue I have is the throttle cable, it always wants to return to Idol.
It doesn’t feel stiff or grind, it just requires constant pressure to maintain speed. At anytime if I take my hand off the throttle within a few seconds it will fall back to Idol, Very annoying.
So any suggestion? I have tried adding a Few drops of Synthetic oil to the throttle Cable pivot Points like the manual says. I can’t find any other place to lube the Cable.
if a cable replacement is required is this a Do-it-yourself job or do I need to take it in.
Thanks
