Old     (robertgwi)      Join Date: Apr 2010       05-05-2010, 11:54 AM Reply
If I am putting 09 Cell boots on an 09 Watson board, am I going to have issues with the Ronix binding screws / cam locks?
Old     (jason95gt)      Join Date: May 2006       05-05-2010, 4:08 PM Reply
If the boots are a size 10, you are going to have lots of problems and should sell them to me.
They are fine, just might need a spacer/washer if the screw is to long.
Old     (hawkeye7708)      Join Date: Feb 2007       05-05-2010, 4:34 PM Reply
http://www.wakeworld.com/forum/showthread.php?t=778954
I posted this up a few days ago... didn't get much for hits, but this chart should answer your questions pretty well!
Old     (hawkeye7708)      Join Date: Feb 2007       05-05-2010, 4:36 PM Reply
From what I can see, there shouldn't be any issues as far as stance options go. Both use a 6" pattern, boot and board. Might be a SLIGHT screw depth discrepancy, but more than likely, they'll work just fine with screw depth and you WILL have all the stance options.
Old     (robertgwi)      Join Date: Apr 2010       05-05-2010, 7:27 PM Reply
Ha - Thanks for your help. They are a 10. If for whatever reason they don't work out for me, I'll shoot you a message.
Old     (ironj32)      Join Date: Jan 2007       05-06-2010, 6:57 AM Reply
works just fine...i rode that setup last year.
Old     (stang_killa_ss)      Join Date: Jan 2010       05-06-2010, 1:02 PM Reply
i had to grind a 1/16" off the end of the screws, for some reason most ronix screws are too long for LF board inserts. i had to do this for my 09 reliks on 09 watson. i know several other guys on WB.com had to do the same with ronix on LF
