Old    Corbin J. Ross (corbin)      Join Date: Jul 2009       04-28-2010, 6:29 AM Reply
So I took the boat out for the first time this year and it over heated a several times. I could watch the temperature raise above 170 and sometimes it would keep going and set off my alarm and others it would drop back down. When the temperature was rising above 170 it would do so quickly, and like-wise, when the temperature would drop from around 190 it was a fast drop. I was able to use the boat for the weekend because after a while it seems to settle and maintain temp around 170. I just wish it hadn't had to hit those super high temperatures before it finally settleed out. The highest temperatures were over 210 I'm sure. I was able to hear the water steaming off inside what I think is the thermostat housing on the front, top of the engine where several cooling hoses attach.
Has anyone else had a sticky thermostat? Or similiar symptoms?
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       04-28-2010, 6:39 AM Reply
prolly bad impeller.
Old    Razzman (razzman)      Join Date: Dec 2006       04-28-2010, 7:37 AM Reply
Yeah i would definately check the impeller, bet you'll find it's bad.
Old    Brad (bstphen24)      Join Date: Apr 2006       04-28-2010, 10:21 AM Reply
Had a similar situation a few weeks ago. I changed the thermostat and impeller and everything works now.
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-28-2010, 10:33 AM Reply
sounds like water pump and or t-stat
you over heated
replace t-stat
impeller
check for weak exhaust hoses
