Old     (phx07enzo)      Join Date: May 2007       04-22-2010, 7:32 PM Reply
So here's the deal, I need to replace the lugs on my trailer because they were rusted on and after having the tires replaced 5 of them are broken.
Here's the problem, I can't get the new lugs in. I think I need to hammer them in however, I've never taken the disks off before. This is a 2007 trailer so do I need to take the greas nipple out to get to a nut holding the disk on??
My sound stupid, I just dont want to screw somthing up. thanks for the help.
Old     (razzman)      Join Date: Dec 2006       04-22-2010, 9:50 PM Reply
Are you talking about the studs? If so i'm assuming you have the rotors off, run them down to a tire store and have them pulled in with an air gun or pressed in as it eliminates them egging the hole by using a hammer. Yes it can be done but it's not the best option.
Old     (liquidmx)      Join Date: Jun 2005       04-22-2010, 10:36 PM Reply
I had a similar experience and used two nuts on the stud to pull them through. This is not the ideal way to press a stud into a rotor and a lot of contention has been brought about by this. Personally I didnt mind doing this to one stud as I didnt want to have to pull the axle and repack the bearings etc. for one stud.
Old     (brycejb328)      Join Date: Aug 2009       04-23-2010, 6:04 AM Reply
[II've done the same thing before... never had a problem. although i do use the loc-tite brand retaining compound where the stud presses into the hub, it may be over kill... but i just worry that after removing one and installing a new one the fit wont be quite as tight.[/I]
Old     (phx07enzo)      Join Date: May 2007       04-23-2010, 7:10 AM Reply
yes but what is the proceedure for getting the rotors off?
