Old    Ryan (liquiddiet)      Join Date: Feb 2009       04-22-2010, 8:06 AM Reply
The dividers between the engine and vdrive compartments in my SAN are a little beat. I want to make some new ones. At an open house last week, i saw the dividers in a new centurion and they looked nice. They were a type of ~3/4" plastic. Anyone have any ideas where i could source suck plastic or an alternative material??
Old    Who Cares (liljohn)      Join Date: May 2007       04-22-2010, 8:32 AM Reply
The material you saw was either HDPE or star board both can be had from tap plastics.
Old    Trace (trace)      Join Date: Feb 2002       04-22-2010, 10:02 AM Reply
I rebuilt mine out of birch plywood soaked in Thompson's Water Seal, and covered them with carpet. See thread:
http://www.themalibucrew.com/forums/...otor-dividers/
UHMW (HDPE) is not a good choice because it will creep under load. King Starboard is stiffer, but expensive and still not as stiff as plywood. Don't know if you're planning to carpet or not, but adhesives don't like plastic. Another choice would be honeycomb aluminum board, but it is very expensive and has to be thru-bolted.
Old    Ryan (liquiddiet)      Join Date: Feb 2009       04-22-2010, 11:01 AM Reply
wasnt going to carpet it, this is what i was thinking
Old    AtTheLake (bmartin)      Join Date: Jan 2007       04-22-2010, 11:07 AM Reply
The bare plastic (Centurion) stuff is easier to keep clean over a carpetted divider, easy to move around and take out, and I haven't any problems with flexing with 500lb bags back there.
Old     (will5150)      Join Date: Oct 2002       04-22-2010, 11:29 AM Reply
My Tige has Proboard with carpet and doesn't flex at all- i put 400 LBS in each locker when we ride.
Old    Who Cares (liljohn)      Join Date: May 2007       04-22-2010, 11:59 AM Reply
My Malibu came with HDPE. As far as the flex is concerned it was easily fixed with 2 pieces of S.S. L metal thru bolted. (if only flexed when we had more than 750# in the locker)
Old    Ryan (liquiddiet)      Join Date: Feb 2009       04-22-2010, 12:11 PM Reply
well i'm trying to source something local, since i'm guessing it will cost $$$ to ship
Old    Dax Jolly (volzalum)      Join Date: May 2009       04-22-2010, 2:40 PM Reply
Here is a link for Star Board:
http://www.jamestowndistributors.com...gn=email042010
Old    Ryan (liquiddiet)      Join Date: Feb 2009       04-22-2010, 3:21 PM Reply
i found a local company that has it, and it is pricey $240 a sheet ouch!
