Old     (ccripps)      Join Date: Oct 2003       04-18-2010, 3:15 PM Reply
Is there a Filter that needs to be Changed on a V-drive Transmision??
My Manual for Mercruiser says change transmision fluid and fliter, but I can find one.
Thanks for any help
Chris
Old     (wake_upppp)      Join Date: Nov 2003       04-18-2010, 7:31 PM Reply
No v-drive filter that I am aware of, but if the manual states it does does it give any more info? Location? Type?
Old     (justintime)      Join Date: Mar 2009       04-19-2010, 12:35 PM Reply
transmissions have a filter
the hurth zf has a screen, you can pull and clean
the borg warners has a screen, but never needs a cleaning unless you pull the tranny out
Old     (ccripps)      Join Date: Oct 2003       04-20-2010, 7:07 AM Reply
Mine is a Velvet drive, So does that mean no filter or screeen to be changed
Old     (justintime)      Join Date: Mar 2009       04-20-2010, 12:53 PM Reply
Velvet has a screen, but no need to clean it, because you need to pull it to clean it
Old     (sdub)      Join Date: Jan 2003       04-20-2010, 1:28 PM Reply
hurth has a screen, but does anybody actually clean it? I would like to know if anybody or any dealer actually cleans the screen. I know its recomended, but I dont think anybody actually does it.
Old     (justintime)      Join Date: Mar 2009       04-20-2010, 1:40 PM Reply
I do
i have seen metal flakes on that screen all the time
no most dealers do not do anything, to tell you the truth
and most do not winterize properly also
Old     (sdub)      Join Date: Jan 2003       04-20-2010, 3:23 PM Reply
have you ever had any problems with the plate that covers the filter leaking after removing for the first time?
Old     (justintime)      Join Date: Mar 2009       04-20-2010, 5:58 PM Reply
nope, you need to push it down on the o-ring
it spins off
Old     (baitkiller)      Join Date: Jan 2010       04-20-2010, 6:05 PM Reply
Just an FYI, the ZF and Hurth drop centers are now recommended to run SAE 30 instead of ATF when placed in commercial duty. A ton of ballast would qualify. Check with ZF or Transmission Marine regarding your serial number for application. They are much happier with 30 and it eliminates that backlash chatter.
